jeeperdude10
May 17, 2014Explorer
I had an issue with my slide as well...bottom would move a bit, but top would not-like something in the way. What I found that worked on mine is on the slide awning (topper), the white plastic ring that looks similar to the manual awning deployment mechanism (has like a "T"bone shaped end). Well mine was loose and cock-eyed, preventing slide from opening, I straightened it and screwed down the set screw. ALL IS WELL. I am told that this is to "stop" the topper on retracting....little did I know it would also prevent from deploying.
Good luck.
Good luck.
38,707 PostsLatest Activity: Jan 05, 2014
