jtfcons
Sep 03, 2013Explorer
Slide out control
My signature HR has a single slide out (LR & Kit. driver side). Occasionally, I have an issue with the engine start up, that is, there is a safety circuit that if it senses the slide is out, will not allow the engine start circuit to complete. BTW, the slide is not out, in fact it is in and travel clamps are in place when this occurs. Does anyone know whether this is a limit switch that needs adjustment and where its located? Or is the in/out position stop strictly a motor torque sensor and is it adjustable? Luckily, there is an override switch that I can depress that allows the start circuit to work, so I've never been stranded, but I would like to adjust this issue away, if I can.
