I have a 2002 Kountry Star Class A.Today the main Slide out will not extend. The 20 amp. fuse is good.When pressing the button,the green light does not light up.Any help will be appreciated.
You need a complete circuit to light up that light. If you can actually get to the slide out motor wires, take your jumper cables and wires out there and connect to the battery and motor wires. If the slide out moves with just the negative connected, it's the negative wire that failed (most likely), if it moves with the positive connected, it's the positive. If it doesn't move at all, it's the motor.
