- shastagaryExplorerthis type of Circuit Breaker is used for a lot of slide outs and is usually close to the battery Circuit Breaker
- wildmanbakerExplorerOurs is an 04 and the key must be in the "ON" position for the slides to operate. It does not mater if the engine is running or not, but if it is running, they operate better.
- crawfordExploreron mine if engine runs slides will not work....
- doxiemom11Explorer IIOur engine does not have to be running. We can operate the slides off the battery without the motor running. The transmission has to be in park and the parking brake set. Our fuse panel is in the bay by the drivers area.
We have a Monaco - George_BeggsExplorerYou must have the parking brake set and the engine running.
- 10forty2ExplorerJust thinking out loud here... but is the parking brake set? I searched for an hour one time to find the problem why my levelers wouldn't deploy, and I found that I had forgotten to set the parking brake. You might also check that the ignition switch is completely in the off position. My slide won't go out with the key turned even slightly.
- philandterriExplorerI am trying to locate the fuses as it is most inexpensive item. If they are ok then I will try something else.
- rgatijnet1Explorer IIIYou might have several interlocks that may make it seem like you have a blown fuse. Make sure that everything is set correctly when you try to operate your slides.
- 2oldmanExplorer IIor a thermal breaker.
- jhladyExplorerPhil,
Probably not a fuse, but a relay. Look in an outside compartment, same side as your slide, and it will probably be inside somewhere. Could be zip tied to the top or side.
Hope this helps.
John
38,778 PostsLatest Activity: Jun 05, 2026
