bisaacs's avatar
bisaacs
Slide Out is Blowing Fuses
My daughter has a Rockwood Roo hybrid that blows a 30 amp fuse whenever the slide out is closed all the way. I thought I had the problem solved by thoroughly lubricating the slide, but the problem has returned. Nothing seems to be binding, there are no wires being pinched--everything worked fine last year.
When the slide is extended, we can hear a "clutch" of some sort making a nasty noise when it reaches the end of its travel. Upon retraction, there is no clutch noise; the fuse simply blows as soon as the gasket around the slide is compressed.
We have found that by being very careful and stopping at exactly the right spot we can save ourselves from a fuse change but this feels more like a workaround than a solution. At the moment I'm thinking of changing the fuse size to 35 amps. This, combined with careful retraction, would probably go a long way towards correcting the situation. I'm sure no dealer would recommend this, but at this point I really don't know what else to do. Any suggestions?
Thanks, Bob
