Bollee wrote:
03 Fleetwood Revolution, the bedroom slide out is not sliding out.
Thought it might be the house batteries were bad / low voltage.
The front slide out is working fine.
Checked fuses and they are not shorted out and seem to be good.
The coach was plugged into 30 Amp service and I also had the generator running.
Thanks in advance with any thoughts and input.
I'm assuming POWERGEAR electric, so disconnect the wires at the motor and see if there's power there, as you didn't give any particulars with it grunting, screaming or uttering not a word.
If no power, you'll need to run an external lead and see if it'll move that way. Reverse the leads, if wrong direction.
Then go for the controller board and you might find a fuse on it, if you haven't checked, already. In fact, you could have a bad controller.
