Teacher_s_Pet
Jul 10, 2014Explorer
Sounds like you have a sheared pin on one side of the slide out motor. If like the ones we have on our Tiffin, a 2" 1/4-20 grade 8 bolt and a Nylock nut can correct until the proper "pin" can be obtained. An 10" adjustable wrench can be used to realign the motor shaft and drive tube or the drive shaft and drive gear at the other end of the shaft if not at the motor.
