dougrainer wrote:
2 Motors only and they are always mounted at the top. You are lubing the "Gib" the plastic slide. You are NOT lubing the motor or the gears. Also, use ONLY the CRC lube, nothing else. Doug
That is what I wondered. I now understand that there is a long shaft from the motor to a gear on the bottom of the shaft. The gear Assy should need no lube, just the gibb. However on the top (of course) the motor has a coupler and according to the video needs to be lubed, not quite as easy as the gibb's
I have the CRC lube and only use it and have found many other uses for it
