Rick_Jay
Aug 18, 2023Explorer II
Dave,
ON EDIT: I just read the manual provided by Doug. (Thanks, Doug! :) ) Interestingly, it does not show a manual retraction method for the front slide of the motorhome, only the rear slide. For the front slide it states (page 218):
If the Slide Room Fails to Operate:
Check the fuse and auto-reset circuit breaker on the slide-out relay module located in the curbside rear electrical compartment. If the fuses and circuit breakers test okay, it will be necessary to call and obtain mechanical assistance to correct the problem.
That's interesting. There must be some way of doing it, but perhaps the manufacturer thought it was too complex or hazardous for the average RV owner to do.
In looking through the manual, your slides are different than mine and the controllers seem to be as well. But IF the controllers came from the same manufacturer, there could be similarities with failure modes.
It could just be a bad ground to the controllers. When I was troubleshooting mine, I found the slide controller ground wire screw loose on the ground bus it was connected to. Upon inspection, the insulation looked burnt. When I stripped away some of the insulation, the copper was burnt about 6" up the wire, so that wire, I'm guessing, had been loose for some time and I believe that explains why our front slide sometimes seemed to really struggle when closing.
BUT...I also had an issue with the controller. As I mentioned, the soldering looked like it had been done by a second grader, and that is probably an insult to second graders. With this issue, the slide wouldn't move. Like it wasn't getting any power, because, well, it wasn't. Since we were on the road I just did the usual "bad connection" maneuver and moderately slammed the controller against the kitchen counter and reinstalled it. It worked, and I was able to bring the slide in. I had to use that trick a couple of times on that trip. Since I wasn't sure if it was a bad solder joint or bad relays, I replaced the relays and resoldered the entire board. NOTE: I also ordered a new "replacement" controller. But the replacement came as a potted assembly, meaning there was epoxy poured all over the board & components so it couldn't be worked on. As it turns out, when I connected it to our rig, the slides didn't work, so either that one was bad or it was the wrong unit.
Well, hopefully the mobile tech will be able to quickly figure out the problem. Please share the solution on this thread so others with a similar rig might be able to use the info. :)
Good Luck,
~Rick
Good Luck,
~Rick
38,782 PostsLatest Activity: Sep 10, 2026
