mmccwill
May 29, 2016Explorer
Before moving the slide in, cut the loose pieces off so they won`t bind, & raise the forward carpet flap up & see if the nylon type block is broke or if any screws are loose -- Lippert makes your slide & the block is a "Lift Block" -- Your slide needs to be adjusted, & always move your slides when your coach is in the travel position, NOT after you level the coach -- That will throw the slide opening out of square -- I know some will say that`s all wrong, but they don`t have a Monaco built coach -- The coach is mfg at the travel position, & not leveled -- If I can be of help, call me -- 480-540-7377 Bill Willard
38,782 PostsLatest Activity: Sep 10, 2026
