- ron_dittmerExplorer III
Grit dog wrote:
Then I must be one funny guy like fourthclassC.fourthclassC wrote:
Hahaha that’s funny!
Personally, I would never have an RV with any slide outs. My feeling is that they detract from the structural in integrity of a vehicle going down the road. Also I don't spend that much time inside the vehicle when camping so no need for the addtional space. Again, just my feeling. - VA-ApraisrExplorer IIHave found most topics, regardless of poster, to be interesting reads. Yep, a few isolated posts have been odd but seldom. One point not discussed could be weather-related to Australia versus USA. Don't think the temps swing a wildly down there and maybe a reason for pro-slide options.
- Grit_dogTrailblazer
Hahaha that’s funny! - ron_dittmerExplorer III"ZERO" from me too.
We special-ordered our 2007 Phoenix Cruiser without a slide-out. Needless to say, our 16 year old rig has never had slide-out problems. It is a very quiet & tight rig that stays warm in the cold, and cool in the heat.
Pending the size of a slide-out, it can weight between 400 and 700 pounds. 3 large slide-outs can add near 2000 pounds to an already over-loaded USA class-C. - pianotunaNomad III
pnichols wrote:
We looked for about a year for a used Class C - before we unexpectedly found and bought a new 2005 Class C in early 2006.
We searched so long because of our list of requirements ... which the new 2005 one we bought in 2006 by pure luck ... just happened to satisfy. Since then I've always guessed that probably the new one we bought had sat on a dealer's lot unsold for one year because it DID NOT have slides!
We did not want slides for improved off-road reliability and overall ruggedness. Years before we had traveled around in remote desert areas in our 3/4 ton Dodge van home-built camper ... and in 2006 bought a Class C that could do the same.
Mine sat on the lot from 2005 to 2009--same reason no slides. I love it. - pnicholsExplorer IIWe looked for about a year for a used Class C - before we unexpectedly found and bought a new 2005 Class C in early 2006.
We did not want slides for improved off-road reliability and overall ruggedness. Years before we had traveled around in remote desert areas in our 3/4 ton Dodge van home-built camper ... and in 2006 bought a Class C that could do the same. - bobndotExplorer IIIThe field of available non-slide floorplans in the over 30’ range seems kind of slim.
It’s difficult enough to get an appointment to repair an rv today. Having a slide with components to operate it only adds to the ‘appointment frustration’ when they malfunction or need service. Especially when you’re on the road.
Slides offer more interior room and offer another option. Once you remove it, you have a huge hole to remove one of those double-wide fridges that seem to becoming more popular.
I know they have an access panel for service but sometimes dealerships have to replace the problematic units as per the manufacturer under a warranty. It seems like those big fridge/ freezer only come in slide models. Maybe that’s why. Just a thought. - fourthclassCExplorerPersonally, I would never have an RV with any slide outs. My feeling is that they detract from the structural in integrity of a vehicle going down the road. Also I don't spend that much time inside the vehicle when camping so no need for the addtional space. Again, just my feeling.
- RobertRyanExplorer
toedtoes wrote:
It appears that most who have responded have 30ft or shorter motorhomes. I suspect the over 32ft motorhome owners will mostly be pro-slide.
I think you be right. Smaller and Larger Class C are pro slide here. Although there are about 35 Class B convertors here. None would think of doing a slide although could be done on the larger Sprinter, VW Crafter and Renault Master Vans, they use as bases. - toedtoesExplorer IIIIt appears that most who have responded have 30ft or shorter motorhomes. I suspect the over 32ft motorhome owners will mostly be pro-slide.
38,780 PostsLatest Activity: Aug 05, 2026
Interesting here Slideouts are common on Motorhomes but not Caravans in Australia. What do you find is an iptimum number and type?
