gutfelt
Oct 24, 2017Explorer
xctraveler wrote:
Assume your slides are electric motor as opposed to hydraulic. If hydraulic look for solenoid to trigger high voltage to hyd pump. If not Hyd ignore this message :)
It wont be "high voltage" it will be 12Volts just like slide motors and everything else on the 12 V side
however if there all hydraulic and if the pump does not activate none will work ;; also newer multi slide systems work off a main controller
it maybe gone bad or the power to it has died
38,783 PostsLatest Activity: Sep 09, 2026
