xctraveler
Oct 24, 2017Explorer
gutfelt wrote:xctraveler wrote:
Assume your slides are electric motor as opposed to hydraulic. If hydraulic look for solenoid to trigger high voltage to hyd pump. If not Hyd ignore this message :)
It wont be "high voltage" it will be 12Volts just like slide motors and everything else on the 12 V side
however if there all hydraulic and if the pump does not activate none will work ;; also newer multi slide systems work off a main controller
it maybe gone bad or the power to it has died
I did misstype, I meant higher amperage. Had a relay failure that took out the hydraulic slides The '12 Phaeton has two Hydraulic and two electric motor - go figure. I was able to close the slides by jumping the two contacts on the relay. yeah that was another mistype, should have said relay to begin with :(
In any event my post is useless if he doesn't have hyd slide operation.
38,783 PostsLatest Activity: Sep 09, 2026
