soxbrat
Jun 17, 2016Explorer
Slider coming apart
I have a 2008 K-Z Sportster toyhauler. The floor of one of my slides is separating from the wall. Has anyone else encountered this? If so, how did you repair it?
mobilefleet wrote:
go outside the rv and look at the floor with slide extended. If it droops or seems uneven in spots you can use good quality screws (3" torx or so) and run a few on the outside edge of the slide. If it's due to water damage your time is limited, you'll have to replace the floor. Usually the slide floor is one continuous piece of plywood or OSB with no support under it, so screws only bite into wood framing or aluminum on the outside edges
