rgatijnet1
Jun 02, 2014Explorer III
I took my old topper to a local boat shop and they just matched it with the same type of fabric. Cost was about $150 each. I did the removal and install, which involves removing the endcap and sliding the old topper off. Not the easiest to do but I did this alone working off of a ladder.
Before you change fabrics, make sure that if you go thicker that you will still be able to slide the topper fabric in to the upper groove and the grove on the slide roller.
Since I had a broken spring on one topper, I changed the spring at the same time and coated it with wheel bearing grease to try to extend the life of the spring in the future.
38,776 PostsLatest Activity: May 15, 2026
