ranankay
Oct 26, 2014Explorer
Thanks Fischer Yes my steps work fine an I have tried the switches you refer too , on my unit they are located up over the exit door where the slide switch is also.
Yes I lso have aux switch on the dash,I think this is for use when the motor battery goes bad it will step in and start the motor.
radio works and I noticed the other day before I took the RV to have it detailed the pump kept running. thanks
38,763 PostsLatest Activity: Dec 25, 2025
