ranankay's avatar
ranankay
slides doesn't work nor my levelers
Not only does my slide not work ,but my levelers want either, and I've checked the fuses undert the dash are there more somewhere else that could cause the problem?
thanks Randy
  • Bad ground wire maybe as motors won't work with just positive from fuse box. Look for usually green wires going from slide and levelers, at their motors or pumps. A lot of times the road vibration loosens them.
  • What unit do you have?
    Are you plugged in?
    Bad batteries or connections.
    Battery disconnect.
    Key in proper position.
    Let's start here until more info.
