Burwoods's avatar
Burwoods
Slides not working
And the drama continues. We have not fixed the battery problem yet, but Dh is in there now, see how they are.
We have motorhome 99 Aerbus in driveway. The livingroom slide when we pushed the slide switch did a little jerk then nothing. We messed around a bit, he hit it for the upteen time and out it went..lovely right..no. Went to do back slide and same click noise as the front, but it decided to never move. Dh goes to front to bring that one in, a test, nope just a light click noise when you hit retract switch. Motorhome livingroom slide is out over neighbours driveway. Battery check done, at 11.6 each. HELP
  • amazingvanstones wrote:
    Plug it in or start the generator or the ignition and get the batteries back up where they belong. That should help for a start.
    good luck
    Larry
    You think batteries are not charged well enough Mh came with 4 year old batteries from someone that was not into a good maintenance schedule. Perhaps purchase of new batteries? Man if that was the problem with all that is going on with this MH what a friggin blessing that would be. As we have no DC power have to be plugged
  • Burwoods wrote:
    We are plugged in, we did not take batteries out, just checked them. There is a click when hitting retract or extent switch that is all. He is looking at fuses under dash now.
    Sorry for multi posts
  • We are plugged in, we did not take batteries out, just checked them. There is a click when hitting retract or extent switch that is all. He is looking at fuses under dash now.
  • Plug it in or start the generator or the ignition and get the batteries back up where they belong. That should help for a start.
    good luck
    Larry
