the bear II wrote:
My choice would be a Dish Tailgater Portable antenna and permanently mount it to your RV. It only weighs 10 lbs and if you setup the mount so it can be attached to the RV or easily removed (unlocked) you would be able to move the antenna away from obstructions
Finally after 2 days and two different forums asking I finally get "A " recommendation.
Been like pulling eye teeth to get an answer to a straight forward question.
Thanks for your input Bear !!!
Does anyone know the brand satellite that has a very small circumference as in 6 to 8 inches and about the same height? I have seen em just don't know the brand.
Thanks all.
