Fleetwood_Coupl
Dec 21, 2014Explorer
small leak (drip) behind the hot water tank.
I was poking around the hidden spaces in the rv looking for a possible place to mount a vac system. I took of the small door under the drawers and TV in the bedroom and found the hot water tank. Noticed a small wet spot and found what seemed like a loose fitting but it almost impossible to get to. The DW was able to contort herself around(yoga instructor) and get a few small turns on it, but it got worse before it got better now it's about the same, shut the hose off and will just use the tank pump until we can get it resolved. Does the tank slide out from the outside by just removing all the screws? Anyone got any ideas. I am thinking it might be the hose not the firing leaking. I will try to post a picture. [img]
[/img]
[/img]
