Fleetwood_Coupl
Dec 22, 2014Explorer
Oh yeah it works been using it everday. Never had a problem since..kinda wierd. It is the first thing that the smart electronic control shuts off when other power is needed..maybe the electric heaters were pulling a header load that night
update hose was not loose. Got the access hole drilled and was able to get it off.
helpful hint...If you remove the support/wood piece that is between the drawers you can really get in there and reach behind the panel over the top. My feet were about 6 inches off the ground but I was able to look through the 2 inch hole and see what I was doing. New hose was $5 at the hardware store.
