DaytonamanExplorerSep 25, 2014Small steel wires protruding from rear bag rr10Discovered small pieces of wire in the side of one rear air spring. They don't pull out. Do Firestone bags have steel wire in them like tires? No leaks, but maybe the bag is failing. Recently had a bl...Show More
ScottGNomadSep 25, 2014Regardless of the cause or origin, replace the bag before you have a catastrophic failure
Related Contentprotruding connectionsProtruding items....Aluminum vs Steel flatbedStainless steel screwsStainless steel screws
