DaytonamanExplorerSep 25, 2014Small steel wires protruding from rear bag rr10Discovered small pieces of wire in the side of one rear air spring. They don't pull out. Do Firestone bags have steel wire in them like tires? No leaks, but maybe the bag is failing. Recently had a bl...Show More
luvlabsExplorerSep 25, 2014Those are pieces of the steel belt from the tire thant blew out. And yes, you should have that air bag replaced ASAP.
Related Contentprotruding connectionsProtruding items....Aluminum vs Steel flatbedStainless steel screwsStainless steel screws
