traveylin
Feb 01, 2015Explorer
I have heard that Texas DPS truck stops use infra red cameras to id brakes that are hanging up running hot when pulling into the safety inspection stops. That could ID a bad brake'
More simply next time you go down a hill using brakes crawl under an check temperatures. If one is much hotter than the others you may have a repair item.
A hung up emergency brake would run hot on level ground and appropriately smell there also
