wolfe10
Feb 01, 2015Explorer
Emergency brake being stuck was likely the shoes rusted to the drum-- not involved here.
Yes, the faster you go, the more braking HP is required to keep your speed in check. The correct speed of descent is one that keeps your speed in equilibrium-- you are neither speeding up nor slowing down WITHOUT USING THE SERVICE BRAKES.
If a PacBrake, have you lubed it? More important if not used frequently.
You need to verify that the exhaust brake is working:
Get up to higher RPM in, say 3rd gear (use Allison shift pad to select 3rd). Take your foot off the throttle-- feel the braking. Toggle the exhaust brake switch ON and then OFF, back ON... You should feel a difference, particularly at higher engine RPM's.
And, if they got that hot, you need to have your brakes and axle seals checked.
