[email protected] wrote:
The front axel clearance is about 7 inches. As for any excess clearance at the top of the jack calendars it appears that they are full retraced. When they are down the shaft is shinny and when retracted you cannot see any of the shinny metal. Can you tell this is the first RV we have had with leveler jack? :>)
Yes:B Don't worry, EVERYBODY was a novice at some time. You misunderstood moving the jack on its mount. The shiny part goes into the Jack outer cylinder. The black outer cylinder is a specific length. The TOP of that cylinder you want to see how close it is to the BOTTOM of the exterior Floor of the Motorhome. IF you have 2 or more inches to move the complete cylinder Upwards closer to the bottom of the floor and you want more clearance you can move it by removing the 4 to 6 bracket mount bolts. Most have just 4. The frame mount the jack bracket bolts to is welded and fixed in place. Doug
