et2's avatar
et2
So does the auto retract awning really work!
Just curious how well they work, if there's a delay perhaps. I was able to reallybtestbit on our last trip. I have it set on the lowest setting ( 12 ). Now there were some pretty windy days with some gusts I'm sure we're over that. Enough to shake the awning pretty good. It never retracted.
Is there a easy way to test them? It's a Dometic
  • et2, be careful with the awning in the wind. Ours will retract but it takes a little time as they go out 9 or 10 feet (on the passenger side), 5 feet on the driver's side. They can puff up while retracting which makes me nervous. At any hint of wind, I pull them in.
    On a couple of class-A Fleetwood's that we rented, they had a switch in the over-head cabinet on the passenger side that would turn on the 'auto-retract' awning feature. Check to make sure if you have a separate switch or not.
    MM.
  • It takes a sustained wind for 20(?) seconds.
    I've discovered that high temperatures will also make it retract.
