pianotuna
May 07, 2017Nomad III
Hi Mrrkva,
That depends on how the installer wired it. Get a meter. Measure the voltage at the battery bank when you KNOW charging is happening. Note it down. Then turn off the battery disconnect switch and check the battery voltage again. If it has dropped then you will have your answer.
Do you know how many watts the panel is?
38,763 PostsLatest Activity: Jul 22, 2018
