Hi snowyegret52,
You won't be able to run portable electric heaters unless there is a massive battery bank, a large inverter (2800 watts), and a way to recharge the bank.
I have 256 watts of panels. When I was a weekend warrior, because I have a medium size battery bank, that was enough to do a great job for me. Now that I'm full time, it doesn't come close to meeting my needs.
500 watts would not be enough, for me, either. I plan on adding 800 additional watts with an additional MPPT controller.
675 watts would be enough if you don't use heaters or the air conditioner.
Here is a simple flow chart.
Budget-->Energy Audit-->Battery bank size-->number of watts-->PWM or MPPT.
One rule of thumb is between 60 and 150 watts of panels per 100 amp-hours of storage. The smaller the battery bank the higher the wattage needed (per 100 amp-hours). Here is a link to the rather special spreadsheet which includes an energy audit, that N8GS has created to help size solar battery charging systems!
Solar Spread Sheet N8GSFor a nice explanation of solar, try this link:
Golden rules of solarsnowyegret52 wrote:
  Will be using 2 portable oil/ceramic heaters in winter which use some electricity.
I’m thinking if I want to live in full time, I should get 1 more 12V or 2 –4 more 6V and piggy back them.  If I can get 2 banks like that and two 250W solar panels, would that be enough?  If I go that route, what kind of charge controller should I get?  (I also have the built in Onan generator which works still plus a 5500W portable generator as well).  Thanks
