NO you are NOT going to run the A/C on Solar
not unless you have about 1000 or more Amphrs of battery and about 2000w of solar panels on the roof
quite frankly you don't have enough room for that
in any situation, say just normal electric use day & night
the batteries have to last all night with out going below 50% discharge, then the solar has to able to supply the recharge while also powering everything used during the day
A/C is just not in the equation
I know one fellow with a 5th wheel trailer, a truck chassis full of batteries, that can run a small converted 5000btu window unit off batteries during the night (4 hours or so just to cool the bedroom), he spends most of the next day recharging those batteries VIA GENERATOR POWER
for solar powered homes they have very special (2) PC A/C units that won't fit an RV, and many times the insulation on the solar stick house, than we can fit into an RV
NaViDa wrote:
MrWizard wrote:
By ac, I assume you mean 120vac, so that probably means tv, p c, DVD, satellite etc..
If that is so... But a "kill A watt" meter, about $20 at home depot
Plug it into the entertainment circuit, plug all your devices into a power strip that is plugged into the kill a watt, and then everyday for a week read the amount of power used
Once you know the real daily avg kilo watt hours used,
We can advise you on batteries and solar panels
I have 505 watts on the roof use the Onan for MW and coffee maker
And still find I need extra generator charging, we use a lot of power everyday
We full-time this is home , different needs for different life/use styles
"AC" meant 'air conditioning'. I just found this 250W mono for a reasonable price, so now i'm interested in at least 1, if not 2, of these at this point. 250W solar panel Renesola JC250S-24-Bb monocrystalline
