lawjohnson
Aug 25, 2019Explorer
Solar Panels
Good evening all, I have a HR Class A that we purchased used. It has three solar panels on the roof that are stationary. The solar system is charging the batteries, (4 6V GC 140Ah units new this ...
grumpy3b wrote:FYI It depends: PWM controller use the full panel amps which go slightly up with increasing temperature. Panel power used for MPPT controllers decreases much more with increasing temperature. So depending upon panel temperature there may not be any significant difference between the 2 controllers.
if you do need to update the solar charge controller I'd suggest to get an MPPT type controller. They are far more efficient that the PWM controllers.
