Panels mounted, wires ran to final spots. Just need some sunlight and I'll give her a whirl.
First time using Dicor.. hope I did it right...
Cleaned the surface good. Put a bead down over my where my holes would be and on my mounting bracket foot.
I had some roofing screws that looked like a good fit, and have a rubber washer on them. Screwed directly into the roof by hand and didnt over tighten. Then covered entire mount foot in dicor. Repeat on all the others.
For now I secured the wires to the roof with Dicor but will come back and use a wire clamp.
Running the wire was the simplest part.
Thanks everyone for the advise.
