MrWizard
Jan 08, 2014Moderator
i found this 400w panel, look at spec 9T6-400, 48.43v
what the OP is looking at is probably similar, high DC voltage
http://www.saferwholesale.com/400W-Mono-Solar-Panel-p/cbi-helios-400-001.htm?vfsku=cbi+helios+400+001&Click=35179&gpla=pla&gclid=CK-P24Oq8LsCFSWCQgodRwQA5g
or this
http://www.sustainablecitynetwork.com/topic_channels/energy/article_3ec7bfa6-8bfd-11e0-9099-0019bb30f31a.html
i don't think would want to try and mount any of these, either choice, on my roof
or this
The Grape Solar Platinum series panels use 96 pieces of 6" high efficiency monocrystalline solar cells to boost power production by more than 70 percent over conventional 230W modules. Higher powered modules mean that installations will require 44 percent less panels. This translates to a cost savings that directly affects the bottom line of successful projects.
Each Platinum series panel weighs 78.2lbs and its size is 77.2" by 51.5" and 1.57" thick. These panels work well with most standard inverters and are ideally suited to roof mount and ground mount applications.
SOURCE: Grape Solar
38,769 PostsLatest Activity: Apr 04, 2026
