Tinstar's avatar
Tinstar
SOLVED & updated: Any mechanical/electrical genius out there
This is a 1994 Tiffin Allegro Bus 34 foot diesel pusher.
Here's my problem: I am having to turn the key to the start position 10 or 12 times to get the engine to crank or if I hold the key in the start position for 6 or 8 seconds the starter will finally engage. I have already replaced the ignition switch on the steering column (actuated by the key) so the starter switch is good and the symptoms are the same with the old or new switch. The starter solenoid is good, the starter is good and the starter relay is good. I've checked all of the above items using the accepted process of elimination with a 12 volt test light. The problem seems to be the start wire from the starter switch is not making good contact somewhere between the starter switch on the steering column and the starter relay in the back engine compartment.
I've attached a photograph of my fuse panel. I am wonder if the yellow fuse in the panel labeled ign (ignition) might be causing the no crank problem. A couple the fuse slots have melted somewhat and/or has broken pins. I've already found and repaired the cause of the melting. That yellow 20 amp ignition fuse slot does have a broken fuse pin on the left side (this is on the the hard wired part where you insert the fuse and not the fuse itself). The fuse is making contact on that one side fuse legs but it's probably not making ideal contact. Anyone know if that fuse might be the cause of the no crank problem.
I have checked the start wire from the ignition to the starter relay by tracing everything accessible. My goodness what a cluster of wires. I have been unable to locate a problem in that wire anywhere that I've been able to find. Like I said, after holding the switch in the start position or repeatedly hitting the start several times, the engine will crank and run fine. There is no problem with the engine performance after it starts. I know I can wire a momentary switch at the drivers position to the starter relay but I would rather fix it the right way.
I'm open for any suggestions and thanks for any input.
