Groover's avatar
Groover
Explorer II
Dec 07, 2020
Some musings on future power trains
As an owner of a 32ft DP with a Cummins 6.7 diesel and two F150 pickup trucks with 3.5 Ecoboost engines I have long felt that the Ecoboost outperforms the Cummins used in this application, is quieter and more responsive. I am not saying that the Cummins doesn't have its own merits, it gives great fuel economy and will probably outlast both me and the coach. Despite those Cummins advantages I have wondered how my coach would drive with an EcoBoost in the back in place of the Cummins. Then lately I have been reading reviews of the hybrid version (PowerBoost) and learned that it is a very capable, efficient and quiet generator as well as strong main powerplant. So what would my coach be like with a PowerBoost engine?
First off, you immediately lose 600lbs in engine weight.
Second, you wouldn't need the generator, that save an additional 420lbs and opens up a large storage area.
And, you would probably save $14,000 (serious EWAG here) in equipment costs, not including generator installation.
So what next?
The current version of my coach already comes with an induction cooktop and electric element in the water heater, leaving space heat the only required task for the propane. So lose the propane altogether, opening up more storage and eliminate another 100lbs or so. With only one engine it would be much simpler to use waste engine heat to heat both the cabin and hot water while boondocking or just driving down the road in cold weather.
Use some of the cost savings to invest in a 120V heat pump for the dash heat and air (you could still have the choice of engine heat there if you wanted too). Eliminate the engine driven AC compressor and have another AC available when parked. This shouldn't take anywhere near all of the space created by removing the generator.
Add a 10kwhr of more battery pack so that more efficient use of the hybrid and generator functions can be made, along with possible solar power and even a limited shore power supply. Note here that Elon expects to have battery cost below $100/kwhr soon, if not already.
You could also remove one starting battery and the DEF tank, saving several hundred more pounds and opening up more storage.
The rear axle could go back another foot or more for more stable handling and reduced rear drag.
There should be plenty of room to add 15% more gasoline if range is an issue.
All in all, the only problem I see potential durability issues but since I am only averaging 6,000 miles per year on the coach and my EcoBoost engines have proven very reliable I don't think that would be a problem. You could even detune the PowerBoost to the level of the Cummins if needed and still use the electric drive boost to outperform the current drive train.
Just food for thought. And maybe motivation for a next generation coach that is compatible with current infrastructure. Hopefully the hybrid options become more available and diverse.
  • dodge guy wrote:
    The little eco boost will not last long at 100% duty cycle! Those little turbos will be glowing red. There is a place for the little boosted motors, but in a full size MH is not one of them!
    My Ecoboost motors have been used harder and with less trouble than my V10 or the older 460 that I had. I would be willing to try it as is but if detuned about 25% down to the power output of my Cummins it should hold up real well. If that doesn't work I still don't believe that the concept is invalid, it just might need an engine designed for that use.
  • Current issue of RV Business is already showcasing some all-electric TTs. The addition of lithium batteries and solar make it workable. One mfr on the West coast is advertising "up to 2 weeks of boondocking or 2-3 nights of air conditioning" just from the inboard batteries and solar.
    Some MHs have already gone all-electric with radiant in-floor hydronic heating and electric appliances...there's a already a genset on board so why do you need propane at all?
    That's what we all said when the eco-boost came out years ago, but that hasn't proven to be the case. Look at all the guys towing big TTs with F-150s with that motor, the duty cycle is no different there than it would be in a Class A.
    The advantage to an eco-boost design is that it allows the F-150 to get better fuel economy when not towing the weight of the trailer. In the Class A, it's effectively never unloaded like taht.
    I don't know if the eco-boost produces enough torque to get a 30,000 lb MH moving though...
  • BB_TX wrote:
    garyemunson wrote:
    What I expect to see is once Tesla starts outputting their electric semis, electric Class As will appear. Probably first as an alternative to high end Diesels, then filtering down to gas units as the price decreases.
    I agree. It may take 20-30 years, but eventually most all vehicles, even the heavy haulers, will migrate to all electric.
    I am looking for something that could happen in my lifetime and for a reasonable price, maybe even a cost reduction. And it also would work in government parks and even boondocking. I don't foresee the feds or most other government parks shelling out the money for the required upgrades. My experience in most federal parks is that the vast majority of their campsites don't have any power run to them. Our political climate and preoccupation of providing for the poor seems to be preventing any campground upgrades, even for those willing to pay for them. I am trying not be political but federal campgrounds have been underfunded for years under all administrations and we have to be real. Finally, I enjoy boondocking and the Ecoboost is quieter than any generator that I have heard.
  • The little eco boost will not last long at 100% duty cycle! Those little turbos will be glowing red. There is a place for the little boosted motors, but in a full size MH is not one of them!
  • What I expect to see is once Tesla starts outputting their electric semis, electric Class As will appear. Probably first as an alternative to high end Diesels, then filtering down to gas units as the price decreases.
