That looks about right for a block diagram. There are some (generally minor) differences in circuit topology that aren't too terribly important--for example, the connection on the engine side between the battery, alternator, and isolator can be rearranged in a few ways, any of which would work fine provided the wires are heavy enough.
Sometimes the aux start solenoid and the isolator are the same gizmo with a somewhat more complicated control wire from the start switch. (Pressing it connects the solenoid control to a house +12V circuit; releasing it connects it to a switched circuit in the chassis, either switched with the ignition or something a little more complex to permit the chassis battery to get recharged before connecting the house battery.) Sometimes they are separate systems, as your diagram shows.
