Lantley
Jun 14, 2018Nomad
Installed 25 gallon auxiliary tank..... sort of!
I installed a Enduraplas 25 gallon Auxiliary tank today to extend my traveling range, and create more fueling options.
The tank is not actually installed it just sits in the bed of the truck. There are large alligator clips that can be attached to the battery to supply 12 volts to the tank's built in pump. You simply pump gas from the Enduraplas tank into your regular tank.
Not quite as fancy or convenient as a true auxiliary tank, but it does give me an extended range and more flexibility between fuel stops. Check out the pictures I think you'll get the point. :D
