wildmanbaker
Dec 28, 2013Explorer
Bud has it correct, even if the clutch is frozen, you can pull it, remove the magnetic coil form the compressor and replace the pulley. If the bearing are seized, just replace the bearings or the hole pulley. $2,900 is very high, unless they are going to replace everything in the system.
Good luck and let us know.
