hershey
Oct 07, 2013Explorer
After 15 years of use, I'd say that silicone is probably as good a sealant as you can get.
But...it the water is getting inside, then its also getting inside the wall too. I would suggest that you add a piece of plywood, just slightly larger than the hole pattern to reinforce the attachment of the tire. Then silicone the entire surface of the outside and inside mounting area along with the area of the bolts.
38,766 PostsLatest Activity: Jan 10, 2026
