Baja_Man's avatar
Baja_Man
Spare Tire Carrier Project - Under Chassis mount
Well, I needed a place to carry my spare tire/wheel. I had it in a storage compartment and it took up too much space. So, I looked underneath my RV and found a suitable location between chassis. I wanted it to sit up as high into chassis as possible (for max ground clearance) so I mounted everything to upper part of C channel chassis. I had to use nuts to space C channel and get it up as high as possible.
I used a TECA Spare Tire Hoist (200# rated). I mounted it to a 2" piece of channel and then mounted channel between/across chassis. I used 2" flat bar across chassis for tire stops. I ran extension crank handle to rear of RV and it worked out perfect as it entered into my rear storage compartment.
Time will tell how well it works and holds up.
I may wrap a bicycle cable and lock around wheel, C channel, and tire stops....for safety...in the event the hoist assembly gives out.
NOTE: I used 3/16" channel; 1/4" flat bar; and grade 8 bolts/lock nuts.
