wolfe10
Oct 08, 2013Explorer
Yup, recommendations without knowing the extend of the problem probably won't do you much good.
As suggested, verify the problem-- how is the spare tire carrier mounted on the inside. Just fender washers? large backing plates? Are the bolt holes wallowed out? If so can you use larger bolts or do you need to fill and redrill.
The bottom line is that you don't want to just calk, you want to FIX the problem-- whatever it is.
38,766 PostsLatest Activity: Jan 10, 2026
