jeffengleExplorerJul 29, 2013spark plug wiresHas anybody had to replace the extenders between the coil & spark plug. Ford engine with a slight miss at light throttle. Reminds me of a bad spark plug wire.
pauldubExplorerJul 29, 2013If you check the codes, even without a check engine light on, it will likely tell you which cylinder has a miss.
Related ContentSpark Plug Confusion ??burnt spark plug wiresFord Spark Plug Problems?Taylor spark plug wiresOnan spark plug
