janstey58's avatar
janstey58
SpeedCo Council Bluffs IA
Hi All, I just wanted to vent on my stop at the CB IA SpeedCo with my Class A DP. It was the worst three hours of my new DPs life! Initially the oil change went well, and they told me they just needed to replace the fuel filters. Then I was told they didn't have the water/fuel filter and I needed to come back. Or, they said you can walk across the street to the truck shop and buy one, which I did with the part# they provided. Well, I spent $32 on the wrong filter they advised, and still no filter.
Finally they said the manager would call today and provide a plan to replace the other filter. Then came the real fun, instead of the $310 or so charge they told me over the phone before the appointment, it rang up at $450. They even charged me $14 to check air in my tires! They said there were numerous "up charges" that were not brought to my attention as the work was completed. I complained, and said I would never return. I started to leave and my RV wouldn't start. Finally after 20 attempts, and (great!) a check engine light, it started and I was on my way. This was crazy and will never do again!!
  • My first time at this, first service on my new to us DP. I will heed your advice, and just wanted to warn others in my area there are likely better choices.
  • Why don't you chalk this one up to a learning experience?
    Why didn't you have fuel filters with you in case you get a bad load of fuel some place??? I always have two spare sets of filters for the main engine and the generator.
    One reason for carrying spare filters is you never know what filters a shop (Speedco or anyone else) is going to put on your engine. I started this after finding that their cross referenced filters don't always have the same micron rating as the OEM filters.
    And, it seems most shops I've been at, even if they have the right micron rating, don't have the filter that uses the clear bowl to see if you have water or contamination. Take your own filters. And I carry a spare clear bowl in case they crack it taking it off of the filter during the change. Yes, it might be their responsibility since they broke it, but if there isn't one available within a hundred miles, then you're going to sit their and wait for one.
    Carry and take your own filters whether you go to Speedco or someplace else.
    Interesting on the air pressure check, I've never been charged for it. I might still be there refusing to pay the "up" charges.
    Bill
