LouLawrence wrote:
Doug, the Splendide washer dryer combo does have a vent hose. There are non-vented versions but that's not what the OP is talking about. I have also seen (and owned) a Splendide with a filter in the exhaust at the exhaust exit. Mine just had a slot you reached into to pull the filter up.
You are correct. I should have stated NON VENTED Splendide Washer/Dryer combo. Also, the way almost ALL OEM's install and secure the Vented dryers, there is no easy way to remove to clean that screen vent. Which is why nobody installs the screen vent, including me. The Oem's and I install a shelf above the combo as the customers do not want to lose that storage space. So, installing the screen vent at the back of the Splendide cannot be done unless you want to lose that extra shelf space.
Doug.
