Stranger wrote:
Never had this happen before. While filling the fresh water tank and pressurizing the entire system, I found that the Washer/Dryer was filling with water.
We have NEVER used the W/D unit. It won't turn on to drain.
Can't open the door because the tub/drum is 1/2 full!
Any ideas?
Thanks.
the only way that can happen is if its plugged into power and turned on. The door locks when this happens
If you take a shop vac and open the filter drain and suck the water up u can save a mess.once water is out and power off the door will open
