rgatijnet1 wrote:
Here is the owner's manual, which you may already have. Manual
On Winterizing the unit it says to open the drain screen on the bottom right to drain what water remains in the tub.
Not sure that this is a good idea with a half full drum but perhaps there is some way to get a hose in there and siphon or pump the water out.
Perhaps if you lower the drain hose, water may run out.
Thanks, rgatijnet1.
Yes I have the manual. What I don't have is 110V to the plug for the W/D, either on Gen or Shore.
I did, however, find two water valves behind the unit. I used my Fiber Optic camera. I've turned those off. Will now run an extension cord to the unit to see If I can get it to spin and drain.
Later, I will trouble shoot the 110 issue.
Thanks, again.
