Stranger wrote:
usersmanual wrote:
the only way that can happen is if its plugged into power and turned on. The door locks when this happens
If you take a shop vac and open the filter drain and suck the water up u can save a mess.once water is out and power off the door will open
Don't have 110 to it. Thinking I didn't properly Winterize the W/D and the inlet valve/valves froze. :M :o
you must have because Door can not lock unless 120V is applied
so if your door is really locked then you have to had voltage to it to make the door lock
