usersmanual wrote:
Bill.Satellite wrote:
In the bottom right corner of the front you will see a small access drawer. You can create a make shift funnel with some tape and paper that leads to a large bowl or small bucket. When you open the access door there is a piece you rotate and the water will come running out. That will solve a piece of the puzzle.
or like I have done and suggested several posts back just stick the shop vac down there and suck up the water as it comes out
works great and no mess
So, first you have to go buy a shop vac! After I suck up the water what do I do with it? Give it to Goodwill? I am not claiming mine is the right way as you appear your method to be but mine does work and it is free.
