BigDaddy1951's avatar
BigDaddy1951
Squeaking From Motor
I have a 2007 Winnebago Voyage on the W22 Workhorse frame with the 8.1 engine. For over a year now when I first crank up, I get a squeaking sound from the motor. I am sure it has to do with the belt system. It is worse when it is damp, as it is most days in Florida. Usually after a few miles it stops. Because of the tight space, and old age, I need advice on where to look first. I don’t want to be left by the road. By the way, the belt looks and feels good, so I am concerned it is a bearing. Thx in advance!
  • Ihad this problem for years on my 2007 w22 8.1 put belt on it every year would go away for 1000 miles and come back.replaced tensioner and and idler and came back got underneath of it with it running and noticed the crankshaft pully wobbling. I owned since brand new and always had the problem. replaced crankshaft pully never had the problem again
  • I have a 2007 W24 chassis with the 8.1L engine and had this problem. I checked idler and tensioner pulleys and they were OK. Tried several belts and noise returned in a short time. I tried NAPA, Dayco, Gates and they didn't last very long until noise returned. 5 years ago I installed a Goodyear Gatorback quiet belt 4061080 and it has been quiet. The belt is a cog-belt design with slots on the groove side that are perpendicular to the grooves. This belt seems stronger than others I have tried and streches less. It is just now making a light chirp at idle speed and usually in the morning or when damp. I will have to now check further now to see if I can determine cause. It does not sound like anything is about to self destruct and the noise goes away above idle. This belt is under quite a bit of stress since it runs water pump, alternator, AC compressor, and Hydraulic pump for steering and brakes.
    The easiest way I have found to handle belt removal and installation is to attach a ratchet strap to the tensioner arm and the other end of strap to suspension spring on passenger side. This way you can remove tension by yourself and easily work with the belt. Just make sure you follow belt routing. I can remove the belt completely from below with this method.
    Looks like I should also take a good look at the crankshaft pulley. Good luck with yours-- Mick
