iquilt888 wrote:
I have a Fleetwood Terra, 2007, with 19k miles. It's Ford V10.
I've only had the vehicle a few months. So I do not know if there have been any components replaced or not.
In the high wind we experienced we did find it necessary to pull off and wait it out.
You can help the sway about 50 percent and it won't cost a dollar, crawl under motorhome and look at the sway bars, you will see a small bar that drops down from frame to sway bar, move that small bar and bolt and move it to the back hole on sway bar, this will tighten up sway, I did this and it works but high winds will still be a issue.
Many have done this and it works.
